can any one help me to solve this linker error for dsPIC33FJ128GP706?
haroon_tech
Member level 2
bangalore
hi,
i have a code for dspic33fj128gp706, i am compiling the code i got this following errors for MPLAB C30 V3.30 ...
Make: The target "D:\code\18_june\adc.o" is up to date.
Make: The target "D:\code\18_june\asm_code.o" is up to date.
Make: The target "D:\code\18_june\Calcu.o" is up to date.
Make: The target "D:\code\18_june\calibrate.o" is up to date.
Make: The target "D:\code\18_june\Flash Operations.o" is up to date.
Make: The target "D:\code\18_june\global.o" is up to date.
Make: The target "D:\code\18_june\I2CSubs.o" is up to date.
Make: The target "D:\code\18_june\interrupt.o" is up to date.
Make: The target "D:\code\18_june\MCP390x.o" is up to date.
Make: The target "D:\code\18_june\UART.o" is up to date.
Make: The target "D:\code\18_june\DEE Emulation 16-bit.o" is up to date.
Make: The target "D:\code\18_june\mainbackup.o" is up to date.
Make: The target "D:\code\18_june\TRY2.cof" is out of date.
Executing: "C:\Program Files\Microchip\mplabc30\v3.30\bin\pic30-gcc.exe" -mcpu=33FJ128GP706 "adc.o" "asm_code.o" "Calcu.o" "calibrate.o" "Flash Operations.o" "global.o" "I2CSubs.o" "interrupt.o" "MCP390x.o" "UART.o" "DEE Emulation 16-bit.o" "mainbackup.o" "C:\Program Files\Microchip\mplabc30\v3.30\lib\dsPIC33F\libp33FJ128GP706-elf.a" -o"TRY2.cof" -Wl,--script="C:\Program Files\Microchip\mplabc30\v3.30\support\dsPIC33F\gld\p33FJ128GP706.gld",--defsym=__MPLAB_BUILD=1,--defsym=__MPLAB_DEBUG=1,-Map="TRY2.map",--report-mem
mainbackup.o: Link Error: Could not allocate section .nbss, size = 2306 bytes, attributes = bss near
MCP390x.o: Link Error: Could not allocate section .ndata, size = 516 bytes, attributes = data near
UART.o: Link Error: Could not allocate section .nbss, size = 242 bytes, attributes = bss near
Calcu.o: Link Error: Could not allocate section .nbss, size = 166 bytes, attributes = bss near
mainbackup.o: Link Error: Could not allocate section .ndata, size = 142 bytes, attributes = data near
Link Error: Could not allocate data memory
Link step failed.
Debug build of project `D:\code\18_june\TRY2.mcp' failed.
Language tool versions: pic30-as.exe v3.30, pic30-gcc.exe v3.30, pic30-ld.exe v3.30, pic30-ar.exe v3.30
Preprocessor symbol `__DEBUG' is defined.
Mon Jun 18 17:40:32 2012
please help me out to solve this linker error?.....
btbass
Advanced Member level 5
Oberon
The eeprom emulation code can take up a lot of memory, depending on how many pages you have defined.
Try to compile without the Emulation to see if that is the problem.
haroon_tech
Member level 2
bangalore
hi btbass,
i removed emulation file from project and compiled no changes same linking errors are giving
btbass
Oberon
Are you using any of the dsp stuff that uses X and Y data spaces?
You could try changing the memory model in the compiler options to large.
haroon_tech
Member level 2
bangalore
yes i am using X and Y data spaces ...
how to change the memory model in compiler ? can you tell me plz...
hi, btbass
i changed the memory model and compiler the code now it is giving this following errors.....
Make: The target "D:\code\18_june\try1.cof" is out of date.
Executing: "C:\Program Files\Microchip\mplabc30\v3.30\bin\pic30-gcc.exe" -mcpu=33FJ128GP706 "adc.o" "asm_code.o" "Calcu.o" "calibrate.o" "DEE Emulation 16-bit.o" "Flash Operations.o" "global.o" "I2CSubs.o" "interrupt.o" "main.o" "MCP390x.o" "UART.o" "C:\Program Files\Microchip\mplabc30\v3.30\lib\dsPIC33F\libp33FJ128GP706-elf.a" -o"try1.cof" -Wl,--script="C:\Program Files\Microchip\mplabc30\v3.30\support\dsPIC33F\gld\p33FJ128GP706.gld",--defsym=__MPLAB_BUILD=1,--defsym=__MPLAB_DEBUG=1,-Map="try1.map",--report-mem
asm_code.o: Link Error: Could not allocate section .text, size = 1010 PC units, attributes = code
data_init: Link Error: Could not allocate section .dinit, size = 610 PC units, attributes = code
Link Error: Could not allocate program memory
Link step failed.
Debug build of project `D:\code\18_june\try1.mcp' failed.
Tue Jun 19 11:58:46 2012
can you tell why this linker errors are coming ? how i can fix this errors....
thank you
btbass
Oberon
It seems to be having problems with 'asm_code'.
Try compiling without that file so you can isolate the problem.
haroon_tech
Member level 2
bangalore
hi, btsass
as you said i removed the asm code from my project and compiled..one linker error is removed but still one is remaining
Debug build of project `D:\code\18_june\try1.mcp' started.
Tue Jun 19 12:53:40 2012
Make: The target "D:\code\18_june\main.o" is up to date.
Executing: "C:\Program Files\Microchip\mplabc30\v3.30\bin\pic30-gcc.exe" -mcpu=33FJ128GP706 "adc.o" "Calcu.o" "calibrate.o" "DEE Emulation 16-bit.o" "global.o" "I2CSubs.o" "interrupt.o" "main.o" "MCP390x.o" "UART.o" "C:\Program Files\Microchip\mplabc30\v3.30\lib\dsPIC33F\libp33FJ128GP706-elf.a" -o"try1.cof" -Wl,--script="C:\Program Files\Microchip\mplabc30\v3.30\support\dsPIC33F\gld\p33FJ128GP706.gld",--defsym=__MPLAB_BUILD=1,--defsym=__MPLAB_DEBUG=1,-Map="try1.map",--report-mem
Link step failed.
thank you ..
btbass
Oberon
data_init comes from the start up file.
It seems to suggest you have run out of memory?
btbass
Oberon
I don't know.
The only thing I can suggest is that you remove one file at a time from the project to see if you can isolate what code is causing the problem.
