so can you have an antenna which is perfectly matched at 800 MHz have zero or negative gain at 800 MHz?
in other words, any link between return loss and gain?
Isn't efficiency the link between return loss and gain? If an antenna is matched, it is efficient. Gain = directivity x efficiency, so gain should be higher unless directivity is super low.
Please save me the textbook definitions of gain and return loss as I am fully aware of them...I would really appreciate a straight-forward reply to my questions with explanation.
