calculation of sigma-delta fractional-N PLL
niklas.zhu
Newbie level 6
Newbie level 6
assume fractional-N PLL using sigma-delta architecture of MASH 1-1-1 and it is for GSM application (channel bandwidth 200kHz )
since MASH 1-1-1 output from -4 to 3, the integer divided number is C, and the output frequency of VCO is Fout (assume Fout is 960MHz)
Is (Fout/(C-4) - Fout/(C+3))/C the VCO output frequency shift?
since the frequency shift should less than 200kHz*x (x<1), assume x=0.01,
so C should be large than 170 and then reference frequency cannot be 26MHz
do I calculate correct?
Please use a little bit Math notation:
If the Mash generate the number interval {-4...3} (3bit signed)
and the divider is modulated with that output by {C-4...C+3} the output frequency is
FOUT=FREF*{C-4...C+3}={FREF*(C-4)...FREF*(C+3)}
The advanatge is that the total of 8 numbers could approach an gaussian distribution. So spurs could be very low.
LaTeX Commands Quick-Menu:
