hi there. I have problem with calculating the resistance of 2 layers of various material (with various resistance and height). The sample of the structure is on the picture. There is no isolation between layers. It's simplified and i don't want the exact calculation, only approach calculation or method.
the width (W) is 10nm for example
I know, that the resistance per square i can get calculating the resistance of layer devided with the height of the layer. But i'm not sure that these layers are simply parallel
i've already tried this calculation, but the results doesn't correspond with the measurement of the resistance at all :| because of this i'm not sure, that in this case it's simply question of simply parallel resistors
