calculating delays for COMBINATIONAL & SEQUENTIAL designs
vjkr
i ve this code.....................................................................................................................................................................
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_unsigned.ALL;
use IEEE.numeric_std.ALL;
entity cn is
port (A:in Std_logic_vector(1 downto 0);
B:in Std_logic_vector(1 downto 0);
C:in Std_logic_vector(1 downto 0);
clk: in std_logic;
A1,a2,a3:eek:ut Std_logic_vector(1 downto 0);
accumulator0:eek:ut Std_logic_vector(1 downto 0);
accumulator1:eek:ut Std_logic_vector(1 downto 0);
accumulator2:eek:ut Std_logic_vector(1 downto 0));
end cn;
architecture Behavioral of cn is
begin
----------------------------------------------------sequential part ------------------START
process(clk)
begin
if clk='1' then
a1<="01";
a2<="01";
a3<="01";
end if;
end process;
----------------------------------------------------sequential part-------------------END
---------------------------------------------------combinational part-----------------START
accumulator1<=a+b+c ;
accumulator2<=a+b+c ;
accumulator0<=a+b+c ;
---------------------------------------------------combinational part-----------------END
end Behavioral;
At synthesis i get
Max combinational path delay:10.610ns
I need help regarding.............
1. What about sequential part?
2. I split the design and verified sequential path only.. result: NO PATH FOUND,NO PATH FOUND,NO PATH FOUND,NO PATH FOUND. means? :/
3. whether my overall delay is SEQUENTIAL+COMBINATIONAL or max of(SEQUENTIAL,COMBINATIONAL)?
thanks
The above code is an analogy of a larger code which consists of ""components""; hence i wrote a similar code for questioning.
First of all, you don't have ANY sequential parts! That clock statement SHOULD BE: if clk='1' and clk'event if you want synchronous element. Is that a typo, or is that what your code really looks like?
Your question (3) is ambiguous. You can have a path that is strictly sequential, strictly combinatorial, or a combination.
For your example, assuming the clk statement is fixed, you have the prop delay of the register (CLK->a1,a2,a3) + the comb. delay of the adder (a+b+c) (I'm assuming a,b,c are the outputs of the synchronous part??)
I would probably help you a lot by drawing a block diagram of the actual signal flow.
@barry: thanks
i didnt know the first point. . . . But problem remains as it is(with varied code)
NO a,b,c are not from sync part....... Then??
then...
You have two totally unrelated paths; one from the clock to a1,a2,a3; and another from a,b,c to accumulator1(2,3). There is nothing in your code showing any relation between those signals.
Which point don't you understand, the comment about your clock statement?
