Englewood
Full Member level 3
- Joined
- Nov 2, 2014
- Messages
- 178
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 16
- Activity points
- 1,294
It has two LEDs inside and each one is different. Will you use the red one or the green one?
I think "Multicomp" is not a manufacturer, I think it is a re-seller and its datasheet has no "typical" graphs.Does the Data sheet tell you the collector to emitter voltage of the turned on transistor?
Of course, as I explained in post #3:When you calculated the base current did you divide 8.3 by 22000 as its a 22 k res?
