Calculating current from a permanent magnetic DC Motor
Vauxdvihl
Member level 5
Hi friends,
i have a permanent magnetic DC Motor and i want to calculate the current flowing through the motor.
The motor is driven by a pulse voltage (pulse width varies, frequency is close).
I have nothing found on the web.
May be that somebody have done it before.
Thank you very much
Regards
Hello,
1.- You can set up a electromechanical model of your motor. Get L, R and Kv (speed constant) an feed it with your power pulses.
2.- You can measure your motor's Kv and remember that *IN COHERENT UNITS* Kv is aproximately numericaly equal to Ki (torque constant) wich is, usualy much difficult to measure.
3.- No name plate in your motor?
I hope this help
Regards
Thanks for your answer !
Do you have some papers about the first point ??
Regards
Sorry, no papers....
Maybe using Google you can get something usefull.
I've done it some 20 years ago using SPICE and CSMP running in a IBM370.
Any decent control systems book will give you a mathematical model for a DC motor.
best regards
another method
Another round about method would be to use the efficiency of the motor. Mecanical power out = efficiency x electrical power in. The efficiency should be one of the rated parameters from the data sheet.
OK thanks a lot !
I will try the ways you've posted
Thanks
Regards
