[SOLVED] calculate thermistor resistance
JohnJohn20
I have a NJ28 NTC thermistor with these characteristics:
Accuracy ±1%
Length 2.8mm
Maximum Operating Temperature +150°C
Minimum Operating Temperature -55°C
Resistance @ 25 °C 10000Ω
Temperature Coefficient Type NTC
Thermal Coefficient -4.6%/°C
Thermal Time Constant 8s
Tolerance ±1%
How would I calculate the expected resistance over the range of 0C to 100C?
I plan to connect these to a PIC to control a pump in a solar water heating system.
Do you just work it out step by step? That is:
25 C 10000Ω
26C (10000-4.6%*10000) = 9540Ω
27C (9540-4.6%*9540) = 9101.16Ω
etc??
That would be easy enough if it is accurate.
Thanks.
Accuracy ±1%
Length 2.8mm
Tolerance ±1%
25 C 10000Ω
etc??
Thanks.
You have to use tables for the right material, in your case it's NA4100, and then approximate values (every 5deg C) in-between ...
Here is the link to tables Resistance vs Temperature:
http://www.pdfdoc.ru/passives/resis...c-thermistor-2-8mm-10k-1-nj28na0103f-697-4578
:wink:
IanP
you could find an example for equations you need in that application note
OK. Thank you IanP. If I look at the thermistor data sheet there is a table, of which one row has the values for alpha = -4.6 @25C and R = 10,000 Ohms @ 25C. This row also has a B(K) value of 4100 +- 1%. Is that where you got the material code NA4100 from?
The table you linked to actually the material code of NE4100. But that would be the same right? Also the alpha@25C is -4.5. Is that significant?
Thank you too sabouras. It looks like you can use the equations to calculate a resistance value between two known values. Without the data table (as linked to by IanP) I only know 1 value which is 10000 ohms at 25C.
So this leads me to think that you can not calculate resistance values for a thermistor. Rather you have to physically measure them. Does that sound right?
Yes sabouras. The other alternative I considered to using a thermistor was the LM335 IC wich has a linear output (and so would be easier to program for) but they require calibration otherwise they can have an error of up to 6 C. All in all the thermistor works out easier.
