[SOLVED] Cadstar 12.1 Importing file issues
lhavens
Junior Member level 2
NJ
Hello all,
I am trying to import a file .dxf file from solid works in to Cadstar 12.1v. The issue i am having is that it says
"Error: A shape on DXF layer 0 is not closed. Shapes of this type must be closed.
The last segment found for this shape ended at (1000.036220, 999.000000) Thousandths of an inch.
The last segment found for this shape ended at (999.855906, 999.000000) Thousandths of an inch.
The last segment found for this shape ended at (999.855906, 1000.166929) Thousandths of an inch.
The last segment found for this shape ended at (1000.036220, 999.657087) Thousandths of an inch.
Error: More than one shape found on the board outline layer"
Which i dont understand because i am working in .7mm, I can not find the shapes that it is talking about. I took out cutouts for the wires and made it a solid and still am having issues. I try the extruded version, and non-extruded.... when I used the non-extruded model it had less errors. I am just stuck. So if anyone can help please let me know.
Greatful for any kind of help,
Lee
