Cadence Virtuoso Layout Editor
rocky.king07
Newbie level 6
Newbie level 6
I want to overwrite process rule like spacing between two metal in cadence module generator utility. I am able to do the same in cadence virtuoso layout editor by using process rule editor by defining new rule and selecting this new rule in automatic router. but, with module generator utility I have no option to select the used defined process rule for routing, its takes default, also some rules I am able to overwrite via cuts, metal width etc. but I am not able to change minimum spacing rule. please suggest method. Thanks in advance.
