suhas_shiv
Full Member level 2
is model level 49 supported by cadence
I am using the TSMC 0.18um model files. When I run the simulator I get an error which says level=49 not supported. I think this is the spice level parameter mentioned in the model file.
Just to see if it works fine, I changed the level to 11 and it seems to work. Is this ok for simulating(are the results going to differ a lot from level 49)? If not, how can I make the tool work for level=49?
I am using version IC5141.
Appreciate any inputs on this. Thanks.
