Show me Netlist regarding analysis statements and signal sources.
// Library name: playground_tb
// Cell name: study_p2004_noise_tb
// View name: schematic
I0 (vcm bgAdj\<2\> bgAdj\<1\> bgAdj\<0\> vd bgBufN bgBufP vd clkChp az \
ir\<3\> ir\<2\> ir\<1\> ir\<0\> vd selBuffCM selBuffGain vcmH vs \
ctat8 ctat1 vbgN vbgP vd vs vs) p2004_ana_bg
V5 (vcm 0) vsource dc=0.5*vd type=dc
V4 (selBuffCM 0) vsource dc=selbuff*vd type=dc
V3 (selBuffGain 0) vsource dc=selgain2*vd type=dc
V2 (vcmH 0) vsource dc=0.66*vd type=dc
V1 (vs 0) vsource dc=vs type=dc
V0 (vd 0) vsource dc=vd type=dc
I6 (vd ir\<3\>) isource dc=iref0 type=dc
I5 (vd ir\<2\>) isource dc=iref1 type=dc
I4 (vd ir\<1\>) isource dc=iref2 type=dc
I1 (vd ir\<0\>) isource dc=iref3 type=dc
V8 (clkSH 0) vsource dc=0 type=pulse edgetype=halfsine val0=vs \
val1=chopping*vd period=2/f_chop delay=0 rise=10p fall=10p \
width=1/f_chop
VAZ (az 0) vsource dc=vs type=pulse val0=vs val1=AZ*vd period=2/f_chop \
delay=0 rise=10p fall=10p width=0.25/f_chop
VCLK (clkChp 0) vsource dc=0 type=pulse edgetype=halfsine val0=vs \
val1=chopping*vd period=1/f_chop delay=0 rise=10p fall=10p \
width=0.5/f_chop
C4 (bgn vs) capacitor c=1n
C3 (vbgN vs) capacitor c=c_load
C2 (vbgP vs) capacitor c=c_load
C0 (bgp vs) capacitor c=1n
I12 (bgAdj\<2\> bgAdj\<1\> bgAdj\<0\>) module_dec2bin vdd=vd \
value=bgAdjsel tol=1e-10
W1 (bgBufN bgn clkSH vs) relay vt1=2 vt2=3 ropen=1T rclosed=1.0
W0 (bgBufP bgp clkSH vs) relay vt1=2 vt2=3 ropen=1T rclosed=1.0
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=30.0 \
tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
digits=5 cols=80 pivrel=1e-3 sensfile="../psf/sens.output" \
checklimitdest=psf
dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
dcOpInfo info what=oppoint where=rawfile
pss pss fund=976.5625 harms=10 errpreset=conservative tstab=0
+ annotate=status
pnoise ( bgBufP bgBufN ) pnoise start=1 stop=100M log=100
+ pnoisemethod=fullspectrum maxsideband=6 annotate=status
modelParameter info what=models where=rawfile
element info what=inst where=rawfile
outputParameter info what=output where=rawfile
designParamVals info what=parameters where=rawfile
primitives info what=primitives where=rawfile
subckts info what=subckts where=rawfile
saveOptions options save=allpub
ahdl_include "/home/aalam/cadence_libs/playground_tb/module_dec2bin/veriloga/veriloga.va"
And show me simulation logfile.
Periodic Noise Analysis `pnoise': freq = (1 Hz -> 100 MHz)
Opening the PSF file ../psf/pnoise.pnoise ...
Using the operating-point information generated by PSS analysis `pss'.
Warning from spectre during PNoise analysis `pnoise'.
WARNING (SPCRTRF-15027): Sweep truncated: 1 Hz -> 43.6516 kHz.
WARNING (SPCRTRF-15029): The following results might not be accurate due to undersampling of the actual frequencies above 48.8281 kHz:
Upper side band of 6th harmonic for stimulus frequencies above 42.9687 kHz.
Set `maxacfreq' on PSS analysis `pss' to 100.006 MHz.
WARNING (CMI-2751): I0.i_buf.I28.I78.I35.M0: Vds(=5.55213 V) has exceeded vds_max(=5.5 V).
WARNING (CMI-2755): I0.i_buf.I28.I78.I35.M0: Vbd(=-5.55213 V) has exceeded vbd_max(=5.5 V).
WARNING (CMI-2752): I0.i_buf.I28.I78.I36.M0: Vgs(=5.55213 V) has exceeded vgs_max(=5.5 V).
WARNING (CMI-2753): I0.i_buf.I28.I78.I36.M0: Vgb(=5.55213 V) has exceeded vgb_max(=5.5 V).
WARNING (CMI-2751): I0.i_buf.I28.I78.I35.M0: Vds(=5.62293 V) has exceeded vds_max(=5.5 V).
WARNING (CMI-2755): I0.i_buf.I28.I78.I35.M0: Vbd(=-5.62293 V) has exceeded vbd_max(=5.5 V).
WARNING (CMI-2752): I0.i_buf.I28.I78.I36.M0: Vgs(=5.62293 V) has exceeded vgs_max(=5.5 V).
WARNING (CMI-2753): I0.i_buf.I28.I78.I36.M0: Vgb(=5.62293 V) has exceeded vgb_max(=5.5 V).
WARNING (CMI-2751): I0.i_buf.I28.I78.I35.M0: Vds(=5.6918 V) has exceeded vds_max(=5.5 V).
WARNING (CMI-2755): I0.i_buf.I28.I78.I35.M0: Vbd(=-5.6918 V) has exceeded vbd_max(=5.5 V).
WARNING (CMI-2752): I0.i_buf.I28.I78.I36.M0: Vgs(=5.6918 V) has exceeded vgs_max(=5.5 V).
WARNING (CMI-2753): I0.i_buf.I28.I78.I36.M0: Vgb(=5.6918 V) has exceeded vgb_max(=5.5 V).
WARNING (CMI-2751): I0.i_buf.I28.I78.I35.M0: Vds(=5.7094 V) has exceeded vds_max(=5.5 V).
WARNING (CMI-2755): I0.i_buf.I28.I78.I35.M0: Vbd(=-5.7094 V) has exceeded vbd_max(=5.5 V).
WARNING (CMI-2752): I0.i_buf.I28.I78.I36.M0: Vgs(=5.7094 V) has exceeded vgs_max(=5.5 V).
WARNING (CMI-2753): I0.i_buf.I28.I78.I36.M0: Vgb(=5.7094 V) has exceeded vgb_max(=5.5 V).
WARNING (CMI-2754): I0.i_buf.I28.I78.I36.M0: Vgd(=5.5076 V) has exceeded vgd_max(=5.5 V).
WARNING (CMI-2754): I0.i_buf.I28.I78.I36.M1: Vgd(=5.5076 V) has exceeded vgd_max(=5.5 V).
WARNING (CMI-2751): I0.i_buf.I28.I78.I35.M0: Vds(=5.74677 V) has exceeded vds_max(=5.5 V).
Further occurrences of this warning will be suppressed.
WARNING (CMI-2755): I0.i_buf.I28.I78.I35.M0: Vbd(=-5.74677 V) has exceeded vbd_max(=5.5 V).
WARNING (CMI-2752): I0.i_buf.I28.I78.I36.M0: Vgs(=5.74677 V) has exceeded vgs_max(=5.5 V).
WARNING (CMI-2753): I0.i_buf.I28.I78.I36.M0: Vgb(=5.74677 V) has exceeded vgb_max(=5.5 V).
WARNING (CMI-2754): I0.i_buf.I28.I78.I36.M0: Vgd(=5.53456 V) has exceeded vgd_max(=5.5 V).
WARNING (CMI-2754): I0.i_buf.I28.I78.I36.M1: Vgd(=5.53456 V) has exceeded vgd_max(=5.5 V).
WARNING (CMI-2754): I0.i_buf.I28.I78.I36.M0: Vgd(=5.54648 V) has exceeded vgd_max(=5.5 V).
WARNING (CMI-2682): I0.i_buf.I28.I78.I35.M1: The bulk-drain junction forward bias voltage (957.077 mV) exceeds `VjdmFwd' = 951.38 mV. The results are now incorrect because the junction current model has been linearized
Notice from spectre during PNoise analysis `pnoise'.
I0.i_buf.I28.I78.I35.M1: The bulk-drain junction returns to normal bias condition
WARNING (CMI-2682): I0.i_buf.I28.I78.I35.M1: The bulk-drain junction forward bias voltage (956.961 mV) exceeds `VjdmFwd' = 951.38 mV. The results are now incorrect because the junction current model has been linearized
pnoise: freq = 1.445 Hz (3.45 %), step = 243.2 mHz (1.72 %)
pnoise: freq = 1.738 Hz (5.17 %), step = 292.4 mHz (1.72 %)
pnoise: freq = 2.089 Hz (6.9 %), step = 351.5 mHz (1.72 %)
pnoise: freq = 2.512 Hz (8.62 %), step = 422.6 mHz (1.72 %)
pnoise: freq = 3.02 Hz (10.3 %), step = 508.1 mHz (1.72 %)
pnoise: freq = 3.631 Hz (12.1 %), step = 610.8 mHz (1.72 %)
pnoise: freq = 4.365 Hz (13.8 %), step = 734.4 mHz (1.72 %)
pnoise: freq = 5.248 Hz (15.5 %), step = 882.9 mHz (1.72 %)
pnoise: freq = 6.31 Hz (17.2 %), step = 1.061 Hz (1.72 %)
pnoise: freq = 7.586 Hz (19 %), step = 1.276 Hz (1.72 %)
pnoise: freq = 9.12 Hz (20.7 %), step = 1.534 Hz (1.72 %)
pnoise: freq = 10.96 Hz (22.4 %), step = 1.845 Hz (1.72 %)
pnoise: freq = 13.18 Hz (24.1 %), step = 2.218 Hz (1.72 %)
pnoise: freq = 15.85 Hz (25.9 %), step = 2.666 Hz (1.72 %)
pnoise: freq = 19.05 Hz (27.6 %), step = 3.206 Hz (1.72 %)
pnoise: freq = 22.91 Hz (29.3 %), step = 3.854 Hz (1.72 %)
pnoise: freq = 27.54 Hz (31 %), step = 4.634 Hz (1.72 %)
pnoise: freq = 33.11 Hz (32.8 %), step = 5.571 Hz (1.72 %)
pnoise: freq = 39.81 Hz (34.5 %), step = 6.698 Hz (1.72 %)
pnoise: freq = 47.86 Hz (36.2 %), step = 8.052 Hz (1.72 %)
pnoise: freq = 57.54 Hz (37.9 %), step = 9.681 Hz (1.72 %)
pnoise: freq = 69.18 Hz (39.7 %), step = 11.64 Hz (1.72 %)
pnoise: freq = 83.18 Hz (41.4 %), step = 13.99 Hz (1.72 %)
pnoise: freq = 100 Hz (43.1 %), step = 16.82 Hz (1.72 %)
pnoise: freq = 120.2 Hz (44.8 %), step = 20.23 Hz (1.72 %)
pnoise: freq = 144.5 Hz (46.6 %), step = 24.32 Hz (1.72 %)
pnoise: freq = 173.8 Hz (48.3 %), step = 29.24 Hz (1.72 %)
pnoise: freq = 208.9 Hz (50 %), step = 35.15 Hz (1.72 %)
pnoise: freq = 251.2 Hz (51.7 %), step = 42.26 Hz (1.72 %)
pnoise: freq = 302 Hz (53.4 %), step = 50.81 Hz (1.72 %)
pnoise: freq = 363.1 Hz (55.2 %), step = 61.08 Hz (1.72 %)
pnoise: freq = 436.5 Hz (56.9 %), step = 73.44 Hz (1.72 %)
pnoise: freq = 524.8 Hz (58.6 %), step = 88.29 Hz (1.72 %)
pnoise: freq = 631 Hz (60.3 %), step = 106.1 Hz (1.72 %)
pnoise: freq = 758.6 Hz (62.1 %), step = 127.6 Hz (1.72 %)
pnoise: freq = 912 Hz (63.8 %), step = 153.4 Hz (1.72 %)
pnoise: freq = 1.096 kHz (65.5 %), step = 184.5 Hz (1.72 %)
pnoise: freq = 1.318 kHz (67.2 %), step = 221.8 Hz (1.72 %)
pnoise: freq = 1.585 kHz (69 %), step = 266.6 Hz (1.72 %)
pnoise: freq = 1.905 kHz (70.7 %), step = 320.6 Hz (1.72 %)
pnoise: freq = 2.291 kHz (72.4 %), step = 385.4 Hz (1.72 %)
pnoise: freq = 2.754 kHz (74.1 %), step = 463.4 Hz (1.72 %)
pnoise: freq = 3.311 kHz (75.9 %), step = 557.1 Hz (1.72 %)
pnoise: freq = 3.981 kHz (77.6 %), step = 669.8 Hz (1.72 %)
pnoise: freq = 4.786 kHz (79.3 %), step = 805.2 Hz (1.72 %)
pnoise: freq = 5.754 kHz (81 %), step = 968.1 Hz (1.72 %)
pnoise: freq = 6.918 kHz (82.8 %), step = 1.164 kHz (1.72 %)
pnoise: freq = 8.318 kHz (84.5 %), step = 1.399 kHz (1.72 %)
pnoise: freq = 10 kHz (86.2 %), step = 1.682 kHz (1.72 %)
pnoise: freq = 12.02 kHz (87.9 %), step = 2.023 kHz (1.72 %)
pnoise: freq = 14.45 kHz (89.7 %), step = 2.432 kHz (1.72 %)
pnoise: freq = 17.38 kHz (91.4 %), step = 2.924 kHz (1.72 %)
pnoise: freq = 20.89 kHz (93.1 %), step = 3.515 kHz (1.72 %)
pnoise: freq = 25.12 kHz (94.8 %), step = 4.226 kHz (1.72 %)
pnoise: freq = 30.2 kHz (96.6 %), step = 5.081 kHz (1.72 %)
pnoise: freq = 36.31 kHz (98.3 %), step = 6.108 kHz (1.72 %)
pnoise: freq = 43.65 kHz (100 %), step = 7.344 kHz (1.72 %)
Total time required for pnoise analysis `pnoise': CPU = 119.713 s (1m 59.7s), elapsed = 55.6425 s.
Time accumulated: CPU = 176.388 s (2m 56.4s), elapsed = 82.7789 s (1m 22.8s).
Peak resident memory used = 283 Mbytes.
Notice from spectre.
813 warnings suppressed.
modelParameter: writing model parameter values to rawfile.
Opening the PSF file ../psf/modelParameter.info ...
element: writing instance parameter values to rawfile.
Opening the PSF file ../psf/element.info ...
outputParameter: writing output parameter values to rawfile.
Opening the PSF file ../psf/outputParameter.info ...
designParamVals: writing netlist parameters to rawfile.
Opening the PSFASCII file ../psf/designParamVals.info ...
primitives: writing primitives to rawfile.
Opening the PSFASCII file ../psf/primitives.info.primitives ...
subckts: writing subcircuits to rawfile.
Opening the PSFASCII file ../psf/subckts.info.subckts ...
Aggregate audit (11:08:06 AM, Thur Jul 19, 2018):
Time used: CPU = 177 s (2m 56.7s), elapsed = 83.4 s (1m 23.4s), util. = 212%.
Time spent in licensing: elapsed = 5.52 s, percentage of total = 6.62%.
Peak memory used = 284 Mbytes.
Simulation started at: 11:06:43 AM, Thur Jul 19, 2018, ended at: 11:08:06 AM, Thur Jul 19, 2018, with elapsed time (wall clock): 83.4 s (1m 23.4s).
spectre completes with 0 errors, 120 warnings, and 30 notices.
No.FYI, I defined a variable maxacfreq as 200M in my ADE L Environment.
+ maxacfreq=100.1M
+ annotate=status
Even if you set pnoisemethod=fullspectrum which is effective only for APS mode, you have to increase maxsideband.
See https://www.designers-guide.org/Forum/YaBB.pl?num=1438976388/2#2
Yes.For the fullspectrum method,
If I set the maxacfreq as = "maxsideband*beat_freq + f_stop",
still do I need to increase the maxsideband parameter?
Even if f_stop is small, large maxsideband is required due to multiple noise folding.I noticed that the simulator truncates the frequency sweep by a number equal to "maxsideband*beat_freq/2" or less.
If that so, why it takes the entry of f_stop from the user?
You can not understand the circuit BW in PSS analysis.From the DesignersGuide forum link you provided,
they discussed that "maxacfreq" is okay when it is higher than the circuit bandwidth.
For my case, I am using chopper clock which is determining the beat frequency,
and the chopper clock has to be higher than the circuit BW itself.
I can not understand what you want to mean at all.Therefore, the maxacfreq formula is violated
when it is set a bit higher than circuit BW.
At most less than 5*Circuit BW.In General,On which basis I can select a f_stop value for the noise/pnoise sweep?
Yes
Again don't use term of "beat frequency".
It is "fundamental frequency".
What is formula ?Could you please clarify me why I still need to increase the maxsideband as it is matches with the formula.
On designers forum link, it is said that the maxacfreq is okay when I set it to a value bit higher than my circuit bandwidth. Say BW 100kHz, so 150 KHz is okay.
But If I have a f_chop = 1MHz (Normally 10 times than BW),
the PSS see f_fund of 1M, and with maxsideband of 10 the "maxacfreq= f_stop + maxsideband*f_fund" will be definitely more than 150K which is estimated on the above line.
That is the violation I mean.
