Does anyone know if there is a way to plot a transient output vs. the values in a paramset file? I am varying temperature in transient analysis and would like to plot my output vs. temperature. I was looking at waveVsWave as a starting point for this, but I would need to somehow generate a temperature wave from the time value pairs.
I wanted to be able to plot a waveform using a calculator expression. X axis is temperature, Y axis is the output.
I think I've got it figured it out. I've used getAsciiWave to convert the csv to a discrete wave and then I use wave vs wave to create the temperature vs output plot.
I needed to use getAsciiWave because I am running the transient simulation with a dynamic parameter set in order to sweep temperature.
