onioni said:It should be "LD_ASSUME_KERNEL=2.4.1".
adsl said:Why not trying IC 610 on FC6?
adsl said:AN1 tried Candence IC5141 on the latest FC6 yet?
% uname -a
Linux show 2.6.22-gentoo-r9 #10 SMP Fri Nov 30 16:10:41 PST 2007 i686 Intel(R) Pentium(R) 4 CPU 3.20GHz GenuineIntel GNU/Linux
% env
MANPATH=/usr/local/lsf_sys/5.0/5.0/man:/usr/share/man:/usr/local/share/man
LESSOPEN=|lesspipe.sh %s
DESKTOP_STARTUP_ID=
GCC_SPECS=
JDK_HOME=/etc/java-config-2/current-system-vm
CONFIG_PROTECT=/usr/share/X11/xkb
GDK_USE_XFT=1
GCC_PATH=/usr/i686-pc-linux-gnu/gcc-bin/4.1.2
LESS=-R -M --shift 5
LOGNAME=sugar
CONFIG_PROTECT_MASK=/etc/env.d/java/ /etc/udev/rules.d /etc/fonts/fonts.conf /etc/terminfo /etc/revdep-rebuild
WINDOWPATH=7
CCACHE_DIR=/var/tmp/ccache
PYTHONPATH=/usr/lib/portage/pym
JAVAC=/etc/java-config-2/current-system-vm/bin/javac
INFOPATH=/usr/share/info:/usr/share/binutils-data/i686-pc-linux-gnu/2.18/info:/usr/share/gcc-data/i686-pc-linux-gnu/4.1.2/info
CVS_RSH=ssh
OPENGL_PROFILE=xorg-x11
PATH=/usr/local/libraries/IBM_PDK/bicmos7xx/rel/utils:/usr/local/contrib/bin:/usr/local/asics/cottonseed/sugar/cadence:/usr/local/synopsys/herc/2004.12/bin/IA32_L24:/usr/local/synopsys/herc/2004.12/scripts:/usr/local/lsf_sys/5.0/5.0/linux2.4-glibc2.1-x86/bin:/usr/local/lsf_sys/5.0/5.0/linux2.4-glibc2.1-x86/etc:/usr/local/cadence/ic5141_usr4/lnx86/tools/dfII/bin:/usr/local/cadence/ic5141_usr4/lnx86/tools/bin:/usr/local/cadence/ius611_usr3/lnx86/tools/dfII/bin:/usr/local/cadence/ius611_usr3/lnx86/tools/bin:/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/usr/X11R6/bin:/usr/local/gnu/make-3.79.1/bin:/usr/atria/bin:/u/sugar/bin:/u/sugar/bin/i686:.:/usr/local/cadence/vsde41_isr0611/lnx86/tools/acv/bin:/usr/local/cadence/assura/assura316_usr1/lnx86/tools/assura/bin:/usr/local/cadence/assura/assura316_usr1/lnx86/tools/bin:/usr/local/cadence/assura/assura316_usr1/lnx86/tools/dfII/bin:/usr/local/cadence/assura/assura316_usr1/lnx86/tools/assura/etc:/usr/local/cadence/icc11241_usr5/tools.lnx86/iccraft/bin
SSH_AUTH_SOCK=/tmp/ssh-xxxxxxxxxx/agent.xxxxx
TERM=xterm
PWD=/usr/local/asics/cottonseed/sugar/cadence
USER=sugar
_=/usr/bin/xfce4-session
WINDOWID=xxxxxxxx
XDG_DATA_DIRS=/usr/local/share:/usr/share
COLORTERM=Terminal
EDITOR=/usr/bin/vim
DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-xxxxxxxxxx,guid=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
DISTCC_LOG=
DISPLAY=:0.0
DCCC_PATH=/usr/lib/distcc/bin
DISTCC_VERBOSE=0
SSH_AGENT_PID=xxxxx
SHELL=/bin/csh
PAGER=/usr/bin/less
SESSION_MANAGER=local/chocolate:/tmp/.ICE-unix/xxxxx
HOME=/u/sugar
JAVA_HOME=/etc/java-config-2/current-system-vm
CLASSPATH=.
SHLVL=3
HOSTTYPE=i386-linux
VENDOR=intel
OSTYPE=Linux
MACHTYPE=i386
GROUP=asic
HOST=chocolate
REMOTEHOST=
CVSROOT=/u/sugar/mydoc/cvsroot
ARCH=i686
CAE=/usr/local/common
CDS_INST_DIR=/usr/local/cadence/ic5141_usr4/lnx86
LD_LIBRARY_PATH=/usr/local/lsf_sys/5.0/5.0/linux2.4-glibc2.1-x86/lib:/lib:/usr/openwin/lib:/usr/dt/lib:/usr/local/cadence/ic5141_usr4/lnx86/tools/lib
CDS=/usr/local/cadence/ic5141_usr4/lnx86
LBS_BASE_SYSTEM=LBS_LSF
CDS_Netlisting_Mode=Analog
SPECTRE_DEFAULTS=-E
ACV_ROOT=/usr/local/cadence/vsde41_isr0611/lnx86/tools/acv
LSF_BINDIR=/usr/local/lsf_sys/5.0/5.0/linux2.4-glibc2.1-x86/bin
LSF_SERVERDIR=/usr/local/lsf_sys/5.0/5.0/linux2.4-glibc2.1-x86/etc
LSF_LIBDIR=/usr/local/lsf_sys/5.0/5.0/linux2.4-glibc2.1-x86/lib
XLSF_UIDDIR=/usr/local/lsf_sys/5.0/5.0/linux2.4-glibc2.1-x86/lib/uid
LSF_ENVDIR=/usr/local/lsf_sys/5.0/conf
ACV_PRERUN_CMD=source /usr/local/common/login.cdsic5141_usr4; source /usr/local/common/login.vsde41_isr0611; bsub -o temp /usr/local/asictechlib/skill/common/ADElmremove.pl;
SITE=rose
ASSURA_UI_NONMEMDATA=1
ASSURAHOME=/usr/local/cadence/assura/assura316_usr1/lnx86
ICCBIN=/usr/local/cadence/icc11241_usr5/tools.lnx86/iccraft/bin
HERCULES_HOME_DIR=/usr/local/synopsys/herc/2004.12
XPROBE=/tmp/xprobe-sugar
SNPS_SYSTYPE=IA32_L24
SYNOPSYS_SYSTYPE=IA32_L24
AVANTI_SYSTYPE=IA32_L24
XAPPLRESDIR=/u/sugar/app-defaults
XKEYSYMDB=/usr/local/synopsys/herc/2004.12/lib-u/X11/XKeysymDB
XNLSPATH=/usr/local/synopsys/herc/2004.12/lib-u/X11/nls
CDS_LOAD_ENV=CWD
TTECH=bicmos7xx
TPROJ=cottonseed
TVER=v0.2
CADENCE_SOURCE_FILE=/usr/local/common/login.cdsic5141_usr4
LSF_PATH_TO_SPECTRE=/usr/local/cadence/ic5141_usr4/lnx86/tools/bin
LSF_PATH_TO_HSPICE=/usr/local/avanti/2005.09/hspice/linux
LSF_PATH_TO_ASSURA=/usr/local/cadence/assura/assura313_usr1/lnx86/tools/assura/bin
IBM_PDK=/usr/local/libraries/IBM_PDK/bicmos7xx/V2.2.2.0
