Maybe help you
1) Install RedHad 7.3
2) Use 1024x864 and 8 bit. The reason is to solve display card issues that some of you have. Don't worry cause you will change it later on in RedHad 9.0
3) Log in as root user
4) Create the following directory /tools in the root directory
5) Open terminal and type csh
6) Move yourself to /tools directory by a) cd .. up to reaching / (root) b) cd /tools
Make sure you are in the /tools directory
7) Install IC50XX this is done by doing the following:
Open a terminal and type sh /mnt/cdrom/setup.sh
Now this will working only if you have softloader.tar in the root of the cdrom. Some of you don't have it and for them move the softloader to the following directory: /tools/cds5/install and run it from there again with terminal run sh softload
8)When asked for install directory type: cds5 (observe that it is created in /tools). This will be created only if you started if your where in the /tools directory when started the installation in terminal.
9) Continue installation. Type Local, (2) other and type /mnt/cdrom
10) Type (4) for cadence catalog
11) a for all
12) After prompt for the next CD do the following: Eject the CD by clicking with the left button mouse on the CD icon in the desktop or mount drive.
13) Insert CD#2
14) Continue with type (3) already mounted until finish installation.
15) In your terminal go to /tools/cds5 add type
ln -s tools.lnx86 tools (observe that new link folder has been created in /tools/cds5 called /tools and by now you should have other installed folders such as tools.lnx86 in /tools/cds5 otherwise the installation place wasn't correct)
16) Copy the license.dat to /usr/local/flexlm/license
If this directory does not exit create it and install it in this directory.
17) Rename the license file to license.dat
18)Change the license header from
#SERVER server ANY 5280
#DAEMON cdslmd …
to
SERVER localhost.localdomain ANY 5280
DAEMON cdslmd /tools/tools.lnx86/bin/cdslmd
Make sure your remove #
19) Logout to a local user not root
20) Open terminal and type csh
21) Set the environment as following in order not to type them again and again each time create a file a type all the commands there and then you will only copy them to the terminal.
22) Set al the environment as follow:
setenv PATH {$PATH}:/tools/cds5/tools.lnx86/bin
setenv PATH {$PATH}:/tools/cds5/tools.lnx86/dfII/bin
setenv PATH {$PATH}:/tools/cds5/tools.lnx86/plot/bin
setenv CDSDIR /tools/cds5
setenv CDS_ROOT /tools/cds5
setenv CDS_INST_DIR /tools/cds5
setenv CDS_INSTALL_DIR /tools/cds5/tools.lnx86/dfII
setenv CDS_LIC_FILE
5280@localhost.localdomain
setenv CDS_Netlisting_Mode Analog
/tools/cds5/tools.lnx86/bin/lmgrd -c license.dat
23)In order to test if the license is running you can type the following but this is not necessary
lmstat -a -c license.dat
24)Now in order to start type
icms - IC Mixed Signal
icfb - IC front to back
But everything you do must be in the same terminal you wrote the environment and run the license and type icms or icfb.
Up until now make sure the IC5 runs in RedHad 7.3
25) Install RedHad 9.0 and do upgrade to RedHad 7.3 not new installation.
26) After the installation log in as root, change the display to your best resolution make sure that on color you chose either 256 or millions but not thousand colors otherwise it wouldn't work.
27) Restart your system with the new display and now log in as normal user.
28)Type again step 20, 21, 22, 23 24
