Cadence Montecarlo Mismatch worst case or Typical?
jgk2004
Full Member level 5
Munich Germany
Hello All,
How does Cadence come up with its mismatch data? When you Monte Carlo can the results be trusted(from mismatch only)? Are they worst case or typical case? Does it take into consideration good layout styles (Common Cent, multiples, symmetry) or bad idiot layout styles( put stuff everywhere with nothing in common) ?
Thanks
John
Hi John,
I'd think they are MC, i.e. anything between best and worst case. You could calculate the probability to get a worst case result, depending on the number of runs.
Re. layout style, pls. s. my answer from Thu, 21 Jan 2010 14:59
Thanks Erikl,
One more question. Is there any reason to do a mismatch when looking at an open loop response(gain/phase)? Even when the simulation is a close loop with Middlebrook/Tian method so thus there should be a DC op which is correct?
Thanks
John
I don't think so.
Even so, in open loop, the output could get into saturation (if the gain is high enough), by this ruins the gain & phase, and this (hopefully) won't reflect the intended application!
Rgds, erikl
