Cadence IC610/ IC5141 on Fedora11?
kumarghz
Member level 5
Penang, malaysia
fedora11 cadence
Hello,
I would like to install Cadence IC610/ IC5141 on Fedora11 (intalled to HDD from live CD).
Please advice me it is possible to do so.
Can I intall it with less problem?
What kind of problems I may face?
Reason why I have choosed Fedora is because I had hard time in intalling graphic driver for my computer with other
linux OS such RHEL5, ubuntu8.
regadrs,
Kumar
ic610 may be ok
ic5141 usr4 may be ok
ic5141 base is not suitable
let me give you 1$ advice.
use ONLY RHEL5. do not use any other OS, you may install it but it will give all kinds of funny errors. your design kit may not work on it. if you have any error during run-time, you will have to debug it. mostly it will be due to 1) non RHEL OS 2) because of Design kit interface or 3)because of design bug.
you can eliminate first 2 by sticking to RHEL5. upgrade your graphics card, it is a cheaper option.
hock
