Cadence IC50 "Stream in" problem?
alson
Newbie level 5
primary cell
I got a "stream out" GDSII file from IC446..
when I run "stream in" in IC5 ,then occur error!
FATAL (299): Stream Out was unable to find a primary cell in the input database. Check the value of the `Primary Cell' option.
stream-in problem in cadence
It seems you had specified a primary cell that doesn't exist in the gdsii file.
Try to leave the Primary Cell blank.
cadence stream in fatal 299
It's work fine...Thanks!
