Cadence Assura Layout circuit extraction
pbuccella
Newbie level 2
Newbie level 2
Hi All,
I have a IC layout in a given process technology and I would like to extract the circuit schematics netlist with cadence Assura extraction tool.
I have the process technology design-kit installed and working.
Is it possible to extract the netlist even if the LVS is not clean?
Thanks,
Pietro
Extract comes before LVS, it's how LVS gets layout data
(connectivity) to chew on.
Now, getting to the analog_extracted view with parasitics,
that probably needs clean LVS to get the pcapacitors on
the right nets and so on.
Thank you for your answer.
Actually I need the extraction of the layout netlist without the parasitics. I am writing the extract.rul file and the only way to debug is running repeatedly LVS and the extraction tool QRC.
Thats why I asked if there is a faster way to extract the layout netlist without doing the full LVS.
Thanks,
Pietro
It should include an extract.rul file. And - as dick_freebird mentioned - you don't need to run an LVS after extraction. The extraction provides the extracted netlist.
