C18 v3.47 reading an excel file
giz.mo
Hello all,
I write my codes in C language and use PIC18 Explorer board with PIC18F8722. I have included <stdio.h> file and tried to read an Excel file with fopen and fscanf. However I just noticed that those functions are not defined in the stdio.h file within C18 Compiler. So is that impossible to read Excel file with C18 Compiler or is there another way? I really need help. Thank you for your replies.
:smile:
giz.mo
First, where is the Excel file located? Does your board include some kind of secondary memory like SDCard? And do your software routines include a filesystem interface (e.g. FAT32)?
If yes, here is the next problem to take on: The Excel file has it's own format. Unless the file is saved in Excel's CSV format, it may not be easy to read and interpret the file. I would suggest writing the routines on a standard PC and then port them to microcontroller.
Out of curiosity: What is the application that requires a microcontroller reading Excel file?
Reactions: giz.mo
    giz.mo
Thanks for your reply. Actually it turned out that it does not have to be an excel file. What I am trying to do is, make the microcontroller read a lookup table from PC, record it in an array for example and than use that array for further processes in my software. I am totally new with microcontrollers and Excel file looked to me an elegant solution but there might be a fundamental misunerstanding about the microcontrollers 8-O
Excell format is quite complicated. You can use it to create data tables but export them as CSV format. This puts the values in sequence with a comma between them and it omits all the 'baggage' that makes up the spreadsheet background data.
It's easy then to import the table into a compiler by simply copy and paste from the exported CSV file straight into the source code.
Brian.
Reactions: giz.mo
    giz.mo
