C18 Code not working
vicky001.iith
Full Member level 1
INDIA
Hello everyone,I am facing a problem.The code given below is not working properly.
Code is whenever i gets an interrupt at PIN B2.Led should blink.But it is not working in the expected way.It doesn't enter in this loop.
      if (INTCON3bits.INT2IF == 1)
              blink_RA();
              delay(200);
                 INTCON3bits.INT2IF = 0;
I am giving interrupt to pin B2 a 5V pulse.
CODE :-
include <p18f26k22.h>
//#include <adc.h>
#pragma config PLLDIV=1,IESO=OFF
#pragma config WDT=OFF,PWRT=ON,BOR=OFF,PBADEN=OFF
#pragma config DEBUG=OFF,STVREN=ON,FCMEN=OFF
#pragma config LVP=OFF,MCLRE = OFF,XINST=OFF
#pragma config EBTR0=OFF,EBTR1=OFF,EBTRB=OFF
#pragma config WRT0=OFF,WRT1=OFF,WRTB=OFF,WRTC=OFF,WRTD=OFF
#pragma config CP0=OFF,CP1=OFF,CPB=OFF,CPD=OFF
#define FOSC_FREQ  (unsigned long)11059200	// 11.0592 MHz
void chk_isr(void);				//checks if int1 set the interrupt
void INT1_ISR(void);
void blink_RA();
#pragma code My_HiPrio_Int = 0x08  // high-priority interrupt location
void My_HiPrio_Int (void)
_asm
GOTO chk_isr
_endasm
#pragma code
#pragma interrupt chk_isr // used for high-priority interrupt only
void chk_isr (void)
if (INTCON3bits.INT1IF==1)	//INT1 causes interrupt?
INT1_ISR();	//YES. Execute INT1 program
void INT1_ISR(void)
    blink_RA();
INTCON3bits.INT1IF=0;		//clear INT1 flag
void delay(unsigned char time);
void blink_RA2();
void blink_RA1();
    unsigned char i,j;
                for(i=0;i<250;i++)
                        for(j=0;j<250;j++);
void blink_RA2()
	TRISCbits.TRISC0 = 0;
        TRISCbits.TRISC1 = 0;
	LATCbits.LATC1 = 1 ;\
        LATCbits.LATC0=0;
        delay(50);
void blink_RA1()
	LATCbits.LATC1 = 0 ;\
        LATCbits.LATC0=1;
        delay(50);
void blink_RA()
        LATCbits.LATC0 = 1;
        delay(50);
void main()
    TRISBbits.TRISB2 = 1; // pir input
    	INTCON3bits.INT1IF=0;	//	clear int1
	INTCON3bits.INT1IE=1;	//	enable int1 interrupt
	//INTCON2bits.INTEDG1=0;	//	make it positive edge
	INTCON2bits.RBPU=1;
	INTCONbits.GIE=1;		//	enable all interrupts
	INTCONbits.GIE=0;		//	Disable all interrupts
        ADCON1 = 0x0F;              //all digital I/O
        blink_RA2();
        delay(50);
        blink_RA2();
        delay(50);
    while(1)
        blink_RA1();
        blink_RA2();
      //  blink_RA();
              blink_RA();
              delay(200);
              blink_RA();
              delay(200);
CODE :-
//#include <adc.h>
void blink_RA();
_asm
GOTO chk_isr
_endasm
#pragma code
void chk_isr (void)
void INT1_ISR(void)
    blink_RA();
void blink_RA2();
void blink_RA1();
    unsigned char i,j;
                for(i=0;i<250;i++)
                        for(j=0;j<250;j++);
void blink_RA2()
        LATCbits.LATC0=0;
        delay(50);
void blink_RA1()
        LATCbits.LATC0=1;
        delay(50);
void blink_RA()
        LATCbits.LATC0 = 1;
        delay(50);
void main()
	INTCON2bits.RBPU=1;
        blink_RA2();
        delay(50);
        blink_RA2();
        delay(50);
    while(1)
        blink_RA1();
        blink_RA2();
      //  blink_RA();
              blink_RA();
              delay(200);
              blink_RA();
              delay(200);
Put this code into your ISR.
Tried this also.Still not working ...
What this functions means to?
void chk_isr (void);
which is your actual ISR?
Also U have disabled GI in your main. Check it once again...
I have defined these functions here.And i enabled GI in main(). Disabling GI was a silly mistake.
But It is not working.
Hey mathespbe, Thanks for your suggestion ... :smile:
It is working now .I forgot to initialize these things.
    OSCCONbits.SCS = 0; // system clock select primary oscillator block
    OSCCON2bits.PRISD = 1; // primary oscillator drive circuit on
    OSCCONbits.IDLEN = 1; // IDLE mode on SLEEP instruction
    ANSELA = 0x00; // make all pins digital
    ANSELC = 0x00;
    ANSELB = 0x00;
