;* A P P L I C A T I O N N O T E F O R T H E A V R F A M I L Y
;* Number : AVR410
;* File Name :"rc5.asm"
;* Title :RC5 IR Remote Control Decoder
;* Date :97.08.15
;* Version :1.0
;* Support telephone :+47 72 88 43 88 (ATMEL Norway)
;* Support fax :+47 72 88 43 99 (ATMEL Norway)
;* Target MCU :AT90S8515
;* DESCRIPTION
;* This Application note describes how to decode the frequently used
;* RC5 IR remote control protocol.
;* The timing is adapted for 4 MHz crystal
.nolist
;.include "1200def.inc"
.include "8515def.inc" ;change this to your device
;.include "m8def.inc"
.list
.equ INPUT =2 ;PD2
.equ SYS_ADDR =0 ;The system address
.def S =R0
.def inttemp =R1
.def ref1 =R2
.def ref2 =R3
.def temp =R16
.def timerL =R17
.def timerH =R16
.def system =R19
.def command =R20
.def bitcnt =R21
.cseg
.org 0
rjmp reset
;* "TIM0_OVF" - Timer/counter overflow interrupt handler
;* The overflow interrupt increments the "timerL" and "timerH"
;* every 64us and 16,384us.
;* Number of words: 7
;* Number of cycles: 6 + reti
;* Low registers used: 1
;* High registers used: 3
;* Pointers used: 0
.org OVF0addr
TIM0_OVF: in S,sreg
inc timerL ;Updated every 64us
inc inttemp
brne TIM0_OVF_exit
inc timerH
TIM0_OVF_exit: out sreg,S
reti
;* Example program
;* Initializes timer, ports and interrupts.
;* Calls "detect" in an endless loop and puts the result out on
;* port B.
;* Number of words: 16
;* Low registers used: 0
;* Pointers used: 0
reset:
ldi temp,low(RAMEND) ;Initialize stackpointer
out SPL,temp
ldi temp,high(RAMEND) ; Commented out since 1200 does not have SRAM
out SPH,temp
ldi temp,1 ;Timer/Counter 0 clocked at CK
out TCCR0,temp
ldi temp,1<<TOIE0 ;Enable Timer0 overflow interrupt
out TIMSK,temp
ser temp ;PORTB as output
out DDRB,temp
sei ;Enable global interrupt
main:
rcall detect ;Call RC5 detect routine
cpi system,SYS_ADDR ;Responds only at the specified address
brne release
andi command,0x3F ;Remove control bit
out PORTB,command
rjmp main
release: clr command ;Clear PORTB
out PORTB,command
rjmp main
;* "detect" - RC5 decode routine
;* This subroutine decodes the RC5 bit stream applied on PORTD
;* pin "INPUT".
;* If success: The command and system address are
;* returned in "command" and "system".
;* Bit 6 of "command" holds the toggle bit.
;* If failed: $FF in both "system" and "command"
;* Crystal frequency is 4MHz
;* Number of words: 72
;* Low registers used: 3
;* High registers used: 6
;* Pointers used: 0
detect:
clr inttemp
clr timerH
detect1: clr timerL
detect2: cpi timerH,8 ;If line not idle within 131ms
brlo dl1
rjmp fault ; then exit
dl1: cpi timerL,55 ;If line low for 3.5ms
brge start1 ; then wait for start bit
sbis PIND,INPUT ;If line is
rjmp detect1 ; low - jump to detect1
rjmp detect2 ; high - jump to detect2
start1:
cpi timerH,8 ;If no start bit detected
brge fault ;within 130ms then exit
sbic PIND,INPUT ;Wait for start bit
rjmp start1
clr timerL ;Measure length of start bit
start2:
cpi timerL,17 ;If startbit longer than 1.1ms,
brge fault ; exit
sbis PIND,INPUT
rjmp start2
;Positive edge of 1st start bit
mov temp,timerL ;timer is 1/2 bit time
clr timerL
mov ref1,temp
lsr ref1
mov ref2,ref1
add ref1,temp ;ref1 = 3/4 bit time
lsl temp
add ref2,temp ;ref2 = 5/4 bit time
start3:
cp timerL,ref1 ;If high periode St2 > 3/4 bit time
brge fault ; exit
sbic PIND,INPUT ;Wait for falling edge start bit 2
rjmp start3
clr timerL
ldi bitcnt,12 ;Receive 12 bits
clr command
clr system
sample:
cp timerL,ref1 ;Sample INPUT at 1/4 bit time
brlo sample
sbic PIND,INPUT
rjmp bit_is_a_1 ;Jump if line high
bit_is_a_0:
clc ;Store a '0'
rol command
rol system
;Synchronize timing
bit_is_a_0a:
cp timerL,ref2 ;If no edge within 3/4 bit time
brge fault ; exit
sbis PIND,INPUT ;Wait for rising edge
rjmp bit_is_a_0a ;in the middle of the bit
clr timerL
rjmp nextbit
bit_is_a_1:
sec ;Store a '1'
rol command
rol system
;Synchronize timing
bit_is_a_1a:
brge fault ; exit
rjmp bit_is_a_1a ;in the middle of the bit
clr timerL
nextbit: dec bitcnt ;If bitcnt > 0
brne sample ;get next bit
;All bits sucessfully received!
mov temp,command ;Place system bits in "system"
rol temp
rol system
rol temp
rol system
bst system,5 ;Move toggle bit
bld command,6 ;to "command"
;Clear remaining bits
andi command,0b01111111
andi system,0x1F
ret
fault:
ser command ;Both "command" and "system"
ser system ;0xFF indicates failure
ret
.exit
