I cant find the link for download .. I only found the download files with examples
I only need the software that makes c source code to hex file without the limitation.
my main lang isnt english so I have a little problem explaining what I need..
yes I need another compiler..lol
since ride7 checks errors and build ( meaning convert the c file to hex file so I could "burn" it to my IC at89c5131)
I used sdcc but it had errors dealing iwth my IC...+ had crashes... so I moved to ride7 which was limited...
I hope it will help me..I am downloading.
I ll write here if I have further questions .
thanks
i think you never used keil... its far superior than ride... ride is used only for students but keil is professionally used by many companies...keil 3 is an IDE which has compiler and can support your controller.... i dont think i need to give you more justification. when you are not ready to try the ready solution i am giving rather than just elaborating the thread without reason......
since i used keil for that IC i told ... its your wish to use or not,,,.............
#include<stdio.h>
#include<at89c5131.h>
unsigned char m_sec,h_sec,sec,min,hour,min1;
bit kodd;
at 0xa1 sbit e;
at 0xa0 sbit rs;
at 0x80 sfr lcd;
at 0xb2 sbit rw;
at 0x90 sbit p10;
at 0x91 sbit p11;
at 0x92 sbit p12;
at 0x93 sbit p13;
at 0x94 sbit p14;
at 0xb4 sbit q1; // p3.3
at 0x97 sbit q2; //p3.4
at 0xb6 sbit q3; // p3.5
at 0xb7 sbit q4; // p3.6
at 0xa6 sbit line;
at 0xa7 sbit ring;
at 0xa2 sbit load1;
at 0xa3 sbit load2;
at 0xa4 sbit load3;
at 0xa5 sbit load4;
