C compiler help needed
shegzzyy
Full Member level 2
Full Member level 2
I want to start learning C language programing but i dont have a compiler.which compiler can i start with that is user friendly?the compiler should be a freeware or gpl compiler and not too large in size.thanks for helping me
Use Eclipse CDT IDE with MinGW Compiler. Download MinGW64 which is better. You can do C and C++ Programming. MinGW is available from sourceforge.net
does mingw64 means its for 64 bits pc?thanks
Pls what does gcc destros means?does it means elipse ide wont work with mingw?i thaught a text editor like notepad can be used to write the code like in micros?does that mean if i use text editor like notepad,it wont be compactible with mingw?thank you
