Re: C Code to send image from PC on ftp server using USB Mod
It's good that your setup is functional. And the hint is already there
"all you need to do is to call that from your program with appropriate paramaters. "
You are using hyperterminal so you'll probably be on a windows system. You will just need to learn how to run an executable from a C program.
Hint: ShellExecute
From your description, you want to work on application layer so you don't need to bother to USB at bus level. If that's the only active modem on your system, commands will automatically go through that.
