c code for writing to and reading from external eeprom
freemanantony
Member level 4
Chennai, India
hello
can anyone help me with c code for writing to external eeprom with i2c and reading from it. the controller used is 8051
Embedded Partner
Full Member level 5
Hubli(INDIA)
hello
first of all you should know the I2C protocol
specifically which controller you are using in 8051?
---------- Post added at 10:56 ---------- Previous post was at 10:56 ----------
check that controller does it contain I2C module or not
---------- Post added at 10:57 ---------- Previous post was at 10:56 ----------
if not you need to develop I2C driver for the controller
g_shyam1682
Full Member level 4
Udaipur-Rajshan-India
Hi friend
You don't give eeprom IC no.
If it is AT24c02 then read datasheet of AT24c02.
this give all required step to read and write with at24c02.
and for this eeprom, does not require any I2C module.
only write code, and eeprom work with any type of Microcontroller.
Hope this is help you.
Shyam
freemanantony
Member level 4
Chennai, India
thank you embedded partner for your time.I am using Philips P89C61X2
---------- Post added at 05:30 ---------- Previous post was at 05:26 ----------
thank you friend . I am using AT24C128 eeprom ic with Philips P89C61X2
---------- Post added at 05:31 ---------- Previous post was at 05:30 ----------
Thank you sumit sharma
