Nov 14, 2007 #1 L london Member level 4 Joined Jun 30, 2006 Messages 79 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,945 Hi, I am using MSP430F449 micro. At a perticular part I need to desable only the timer interrupt, key interrupt should be in active, so can any one suggest the C code command for that? thanks
Nov 17, 2007 #2 bobcat1 Advanced Member level 4 Joined Jul 10, 2002 Messages 1,284 Helped 99 Reputation 198 Reaction score 34 Trophy points 1,328 Activity points 8,546 Re: help me hi All interrupt are disable on reset , the timer interrupt will work only if you set it on All the best Bobi
