lodup29
Newbie level 2
I’m weighting the impact of placing bypass capacitors beneath their corresponding pin rather than next to it. Looking around, I found a few rules of thumb stating that the parasitic inductance of a via would be around 1.2 nH while the inductance of a trace would be around 1 nH/mm. Considering that the board must follow the IPC-7351B (density A) guidelines which, unless I made a mistake, implies that all components must be at least 1mm apart, I’m under the impression that placing the capacitor on the same side and next to the pin is at best virtually equivalent to placing the capacitor beneath the pin with a via right next to the pad. Yet I found I few guidelines stating that the bypass capacitors should be placed on the same side of the IC. I guess I’m missing something here. Thanks.
