hi
I wish to help the building the whistle by MATLAB when the input where the zero issued a humming sound and if the input where the one issued any music
sound
Just curious since I don't have it, does MATLAB allow synthesising sounds?
I mean, one may write some time functions, sinusoidal or else, and combine them with different amplitudes. Then there will be a command that lets MATLAB generates via the PC sound card the resulting complex waveform.
You know, I try understanding your question
Added:
For instance, what is the last problem you solved on MATLAB?
Note: In case you didn't get an answer yet (not necessarily on this forum), you may like to add any reply here to pop up this thread again. You may like also giving a further detail on what confuses you... starting from the first step perhaps.
Is it possible that most here don't use MATLAB as I :-?
