nehsr
Hello,
My fast fourier transform's butterfly is not giving me the appropriate results when simulating, can anyone please help me with it?..... the codes are as follows:
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 library IEEE; -- library name and library use clause use IEEE.std_logic_1164.all; -- specifies multi level logic system use IEEE.MATH_REAL.ALL; package fft_pkg is type complex is record r : real; i : real; end record; type comp_array is array (0 to 7) of complex; type comp_array2 is array (0 to 3) of complex; function add (n1,n2 : complex) return complex; function sub (n1,n2 : complex) return complex; function mult (n1,n2 : complex) return complex; end fft_pkg; package body fft_pkg is --addition of complex numbers function add (n1,n2 : complex) return complex is variable sum : complex; begin sum.r:=n1.r + n2.r; sum.i:=n1.i + n2.i; return sum; end add; --subtraction of complex numbers. function sub (n1,n2 : complex) return complex is variable diff : complex; begin diff.r:=n1.r - n2.r; diff.i:=n1.i - n2.i; return diff; end sub; --multiplication of complex numbers. function mult (n1,n2 : complex) return complex is variable prod : complex; begin prod.r:=(n1.r * n2.r) - (n1.i * n2.i); prod.i:=(n1.r * n2.i) + (n1.i * n2.r); return prod; end mult; end fft_pkg; library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.MATH_REAL.ALL; library work; use work.fft_pkg.ALL; entity fft8 is port( s : in comp_array; --input signals in time domain x3 : out comp_array --output signals in frequency domain ); end fft8; architecture Behavioral of fft8 is component butterfly is port( s1,s2: in complex; --inputs w :in complex; -- phase factor x1,x2 :out complex -- outputs ); end component; signal x1,x2: comp_array := (others => (0.0,0.0)); --phase factor, W_N = e^(-j*2*pi/N) and N=8 here. --W_N^i = cos(2*pi*i/N) - j*sin(2*pi*i/N); and i has range from 0 to 7. constant w : comp_array2 := ( (1.0,0.0), (0.7071,-0.7071), (0.0,-1.0), (-0.7071,-0.7071) ); begin --first stage of butterfly's. bf11 : butterfly port map(s(0),s(4),w(0),x1(0),x1(1)); bf12 : butterfly port map(s(2),s(6),w(0),x1(2),x1(3)); bf13 : butterfly port map(s(1),s(5),w(0),x1(4),x1(5)); bf14 : butterfly port map(s(3),s(7),w(0),x1(6),x1(7)); --second stage of butterfly's. bf21 : butterfly port map(x1(0),x1(2),w(0),x2(0),x2(2)); bf22 : butterfly port map(x1(1),x1(3),w(2),x2(1),x2(3)); bf23 : butterfly port map(x1(4),x1(6),w(0),x2(4),x2(6)); bf24 : butterfly port map(x1(5),x1(7),w(2),x2(5),x2(7)); --third stage of butterfly's. bf31 : butterfly port map(x2(0),x2(4),w(0),x3(0),x3(4)); bf32 : butterfly port map(x2(1),x2(5),w(1),x3(1),x3(5)); bf33 : butterfly port map(x2(2),x2(6),w(2),x3(2),x3(6)); bf34 : butterfly port map(x2(3),x2(7),w(3),x3(3),x3(7)); end Behavioral; library IEEE; use IEEE.STD_LOGIC_1164.all; use IEEE.MATH_REAL.all; library work; use work.fft_pkg.all; entity butterfly is port( s1 : in complex; --inputs w : in complex; -- phase factor x1: out complex -- outputs ); end butterfly; architecture Behavioral of butterfly is signal xxx : integer := 0; type comp_array is array (0 to 7) of complex; type comp_array2 is array (0 to 3) of complex; -- function add (x1, x2, x3 : comp_array) return comp_array; -- function sub (x1, x2, x3 : comp_array) return comp_array; -- function mult (x1, x2, x3 : comp_array) return comp_array; --butterfly equations. function sub (s, w : comp_array) return comp_array is variable diff : comp_array; variable x1 : comp_array; variable x2 : comp_array; variable x3 : comp_array; begin x1(1) := sub(s(0), mult(s(4), w(0))); x1(3) := sub(s(2), mult(s(6), w(0))); x1(5) := sub(s(1), mult(s(5), w(0))); --2nd stage equations: x2(2) := sub(x1(0), mult(x1(2), w(0))); x2(1) := sub(x1(1), mult(x1(3), w(2))); x2(4) := sub(x1(4), mult(x1(6), w(0))); x2(5) := sub(x1(5), mult(x1(7), w(2))); --3rd stage equations: x3(4) := sub(x2(0), mult(x2(4), w(0))); X3(5) := sub(x2(1), mult(x2(5), w(1))); x3(6) := sub(x2(2), mult(x2(6), w(2))); x3(7) := sub(x2(3), mult(x2(7), w(3))); return diff; end sub; --1st stage equations: function add (s, w : comp_array) return comp_array is variable sum : comp_array; variable x1 : comp_array; variable x2 : comp_array; variable x3 : comp_array; begin x1(0) := add(s(0), mult(s(4), w(0))); x1(2) := add(s(2), mult(s(6), w(0))); x1(4) := add(s(1), mult(s(5), w(0))); x1(6) := add(s(3), mult(s(7), w(0))); --2nd stage equations (sum): x2(0) := add(x1(0), mult(x1(2), w(0))); x2(3) := add(x1(1), mult(x1(3), w(2))); x2(6) := add(x1(4), mult(x1(6), w(0))); x2(7) := add(x1(5), mult(x1(7), w(2))); --3rd stage equations(sum): x3(0) := add(x2(0), mult(x2(4), w(0))); X3(1) := add(x2(1), mult(x2(5), w(1))); x3(2) := add(x2(2), mult(x2(6), w(2))); x3(3) := add(x2(3), mult(x2(7), w(3))); return sum; end add; begin --end process; end Behavioral;
