Burning bootloader, Device signature = 0xffffff
xmen_xwk
Full Member level 3
I have a Atmega328P-AU, soldered in PCB with all other components. And I'm trying to burn the bootloader into that Micro controller through Arduini Mini Pro.
I have uploaded the ArduinoISP scatch to MiniPro. Did wiring like this
(MU) = (Mini Pro)
MOSI = MOSI
MISO = MISO
SCK = SCK
RESET = SS(Pin 10)
GND = GND
VCC = VCC
and I double checked the wiring, all seems good. But still arduino IDE shows this error.
C:\Users\..\Desktop\arduino-1.0.1\hardware/tools/avr/bin/avrdude -CC:\Users\..\Desktop\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328 -cstk500v1 -P\\.\COM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xde:m -Ulfuse:w:0xff:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Users\..\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA328
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Recv: . [ff]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
################################## | 100% 0.06s
avrdude: Device signature = 0xffffff
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
I tried with Arduino IDE 1.0.6 and 1.0.1. But I think problem is in hardware because its showing Device signature = 0xffffff. But I'm not sure which part I should look into ? Crystal is correctly wired and all other components.
One more question, can other components on PCB cause this problem ? There are other ICs and components using I2C and Digital pins of MU.
Thank you :)
How are you communicating with the arduino pro-mini and your PC with the IDE on it ? If the dtr pin on the pro-mini is connected to the interface, it may be resetting the pro mini when the bootloader upload begins. It may be necessary to put a 10uF capacitor between the pro-mini's reset pin and ground just before starting the bootloader upload to keep the pro mini from being reset. An Arduino Uno has to have this done when used as an ISP programmer.
Yes Pro Mini is connected to an interface, and I removed the DTR Wire because do not require to reset arduino mini pro. But result stays same.
Got it working, the actual problem was CAP was shorted to GND underneath.
