[SOLVED] Burglar Alarm System using actuator
WhyWhy
Member level 4
Member level 4
Hi all,
I doing a mini project which is burglar alarm system for house using sensor and actuator. But i having problem about the actuator type and the voltage need by actuator. I worry the circuit provide voltage just enough operate the alarm but insufficient for operate the actuator.
1) Any suggest about which actuator i need to use?
2) How much voltage need to operate the actuator ?
Reference Link:
https://www.electroschematics.com/2162/burglar-alarm-system/
Regards,
YY
do you mean the speaker aka loudspeaker? It says 8 ohms 1 Watt. Should be a bit loud. Try a 4 ohm 2 Watt speaker if you want more volume, but you would need a different transistor - the C337 would burn out.
Can speaker act as a actuator in my project? Mean my project sensor will be infrared sensor and actuator will be speaker ?
the diagram shows a speaker..............................what do you mean by actuator?!
hi kam,
Sorry i abit confuse about the actuator. For me speaker is not a actuator,because i'm thought the actuator is something like motor,solenoid. So speaker is count as actuator?
Thanks for help :)
Regards,
YY
hi kam,
Thanks for help :)
Regards,
YY
What you mean with this "So speaker is count as actuator?" ?
Actuator
https://en.wikipedia.org/wiki/Actuator
Best regards,
Peter
That's what an actuator is to me!
They came in all shapes and sizes, in all electrical requirements - what does your need ?
My project "A burglar alarm for a house" which require a sensor and actuator.
Sensor = infrared
Actuator = Speaker
Is this correct?
Sensor = infrared
Actuator = Speaker
Is this correct?
In post #2 you already get answer, also if you better look circuit you will see that you need speaker of 1W 8R.
Best regards,
Peter
