importing model orcad pspice
The file you get has a .mod extension. pSpice only recognizes library files with .lib extension. Try to rename the file you have with a .lib extension as the syntax of the model seams to be correct (It includes directives like "LOT/UNIFORM" and "DEV/GAUSS" which are used for Mote Carlo analysis).
You also need to :
- add this new .lib file in the library list.
- create a schematic drawing for the component in a .slb file with the model editor(starting from a existing one is easier).
