bug lpc1768, interrupt makes system freeze/crash
Brecht
Newbie level 5
Dear,
A system based on arm cortex m-3 and programmed in c/c++ containing a gps-module had this problem where it froze down. After testing I think it has to do with the interrupt-usage in de gps.cpp.
Not using these interrupts make the system run fine but then it loses the gps-functionality.
The students of previous year basically used it in every method/procedural in the gps.cpp file
I give some code (cannot give all because of confidentiality contract..)
but something is wrong here, that makes the system total go crash/freeze
what is the relationship between interrupts and stack overflow?
what kind of interrupt is NVIC_DisableIRQ()
should I be using a different kind of interrupt?
code:
#define GPS_UART UART1_IRQn
Serial gps_port(P2_0, P2_1);
void GPS_command_sentence(char command[])
// Disable interrupts for a while
NVIC_DisableIRQ(GPS_UART);
gps_port.printf(command);
// Enable interrupts
NVIC_EnableIRQ(GPS_UART);
In the initialization they basically use this method/procedural for command=setDGPSmode,setSBASenabled,setNMEAoutput,.. gps related commands
thank you for your help..
