faisal78
Member level 3
Hello friends,
I was looking in regards to buck regulators and i am wondering why is it that, for a fixed output voltage/output load.... the regulator is more efficient with lower Vin, as opposed to higher Vin.
e.g. https://www.ti.com/lit/ds/symlink/tps62590-q1.pdf datasheets.
See Figure 2, there is ~5% efficiency difference for Vin=5v vs. Vin=2.7v for Vout=1.8v.
I had always thought, at higher input voltages, the duty cycles will be smaller, hence better efficinecy, since its 'sleeping' more.
The reason for me asking this is, I have a 7.4v lithium ion battery which I have to power a 1.8v MCU.
There are also a couple of other 2.8v regulators in my system.
Most power regulatos have a high limit of 5.5v, so I need a pre-buck regulator prior to seeing the lower voltage bucks/LDOs.
So I have two bucks in series from 7.4v, as an intermediate step down.
I am trying to find out the most sweet spot for this intermediate buck regulator.
