buck converter using arduino control n mosfet
aspirecole
Member level 1
Member level 1
how should i drive this n mosfet with arduino pwm..is it hig side or low side?.. i wan to build a buck converter
You want to drive a PMOS if you are using the picture you have shown. You need a MOSFET driver to do a NMOS on the high side because you need a bootstrap to get a higher potential on the gate than what your Vin is. Make sure to have your Arduino isolated and protected because of the switching current of the MOSFETs.
if im using gate driver mcp1407 and drive the mosfet with 9V is it accpetable..or do you have any driver suggestion..
A standard lowside driver like MCP1407 can be used if Vin is in a suitable range (not above 12 - 15V) and the driver is supplied by Vin. Otherwise you need a level-shifting driver.
i think mcp1407 will not work as the input is 24.. im planning to use ir2117 with 9V Vcc...
