It is somewhat confusing for me, that is why i asked the question.it appears to say 4 wires used in parallel, 5 layers to be used
--- Updated ---
2 turns per layer if the 10 turns total is correct ...
To keep things simple ,, how many circular mills needed for 30amp. if i use 25awg wire how many to use in parallel (I have limited options) .
If use a single torroid , what size is recommended from your experience.
output 12-14 say 15-20 amps only. But thought about going with a 30amp design
So what is the problem ?I went through micro metals site and saw options. They all use a minimum OD=26mm cores and next one OD=38mm torroids.
I will try to get this ..So what is the problem ?
Just buy one of the specific toroids listed in their solution, and job done.
These often come up on e-bay, or do a google search.
