ogulcan123
Member level 5
- Joined
- Apr 23, 2011
- Messages
- 81
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Istanbul, Turkey
- Activity points
- 2,024
I very strange thing happens that I hope somebody else had the same issue before.
I've designed a buck converter circuit using L7981A exactly as it is described in its datasheet. I normally works fine.
If I first plug the connector, then open the power supply, it works perfectly fine.
However, if I first open the power supply, then plug the connector, it burns (i.e. the input terminal of the buck IC becomes short).
Circuit draws around 100mA. My schematic is as follows:
Thanks in advance.
Thanks in advance.
