Buck boost design helps for the bidirectional battery charges
deepakchikane
Full Member level 3
Full Member level 3
Mumbai, Maharashtra, India, India
Hi
can anyone help me build a Buck-Boost converter.
application: Bidirectional Battery charger.
any articles.. idea will be appreciated.
1)12v dc-72v dc (Boost mode)
2)72v dc to 12 v dc (Buck mode)
What can be the control logic..??
Try out IC LT®8705. It will be mapped for both of your needs - boost and buck converter. The best thing about LT®8705 is that it can generate output voltage above, equal to or below the input voltage depending on the need.
will it be bidirectional...??
I think the question is misleading. You are not actually looking for a buck-boost converter. What you need is a simple synchronous switcher (two switches + one inductor) that is controlled for bidirectional operation. Buck in one direction, boost in the other.
Unfortunately I'm not aware of a switch controller IC supporting bidirectional operation (Some might exist though). You can design your own analog controller around existing PWM controller ICs or use a dsPIC or similar fast microcontroller to setup a digital controller.
yes fvm.. it is right.
can u help me to design such projects..??
one basic thing, i want to design for 100 w @100 khz...
pls,help me to calculation of inductor for that and also capacitor selection..
pls
Inductor can be choosen as for standard boost or buck converters, e.g. 20 or 40% ripple current results in 64 respectively 32 µH. So 39 or 47 µH would be a good choice.
Capacitors at least some 100 µF at each side. High voltage side has discontinuous current and higher ripple, about 3.5 A rms, capacitors must be prepared for it.
I'm suggesting this topology. By feeding Vo instead of Vi you get boost operation.
For the basic equations see https://en.wikipedia.org/wiki/Buck_converter
