Hey guys,
So I am trying to design a DC/DC buck/boost non-inverting converter for one of my classes. I am going to be using a transformer rated at 24V/2A on the secondary side, with a 12V center tap. I also want to use two N-Channel MOSFETS to act as my switches, so when one is on, the circuit is bucking, and when the other is on, it is boosting. An Arduino is being used as a microcontroller in order to supply the pulse. Well that is the main components of my idea.
The MOSFET I am using is the IRFZ34N Power MOSFET. The problem I am having is I can get the circuit to buck, however I am not able to get it to boost. I believe this is due to the gate current not being high enough to turn the second MOSFET on, in order for the circuit to boost. I came to the conclusion that I will be needing a MOSFET driver in order to boost the gate current of the second MOSFET. Is this idea correct? If so, how would I go about selecting a compatible driver for the IRFZ34N? If you guys could help me out, I would very much appreciate it.
Oh and what type of rectifier would you guys recommend I implement when converting the voltage from the transformer?
Thanks again
