Bubblesort in assembly problem
Aramil
Newbie level 1
Hello,
I'm trying to write a bubblesort algorithm for a class assignment but it doesn't seem to work.I 've checked my code over and over again..Could someone point out any mistakes?
P.S It's written for nasm compiler for a 386 proccessor
pastebin.com/sVj8QSce
(EDIT: Link to original code: ASM (NASM) | [ORG 0x100] [BITS 16] ;--- - Bubblesort NASM - sVj8QSce - Pastebin.com)
For some reason NASM would crash on my '486 -- this is written for TASM:
.286P
CODE SEGMENT
ASSUME CS:CODE,DS:CODE
ORG 00100H
PUSH CS
POP DS
MOV BX, OFFSET S
CALL BSORT
MOV AX, 0B800H
MOV ES, AX
LEA SI, [S]
MOV DI, (8*160)+80
MOV AH, " "
CLD
	PRINT:
LODSB
OR AL, AL
STOSW
JNZ PRINT
RET
	BSORT:
PUSH AX
PUSH SI
PUSH DI
MOV SI, 10	;LENGTH OF DATA STRING
	OUTER:
XOR DI, DI
DEC SI
JZ OUTER_DONE
	INNER:
INC DI
CMP DI, SI
JA OUTER
	COMPARE:
MOV AX, [BX+DI-1]
CMP AL, AH
JNA INNER
	SWAP:
XCHG AL, AH
MOV [BX+DI-1], AX
JMP SHORT INNER
	OUTER_DONE:
POP DI
POP SI
POP AX
RET
S DB "9876543210", 000H
CODE ENDS
END CODE:00100H
(EDIT: The above must be compiled as a ".COM" file.)
(EDIT: By the way, you definitely should place a "CLD" or "STD" instruction before instructions such as "LODSB", "LODSW", "LODSD", "STOSB", "STOSW", "STOSD", "MOVSB", "MOVSW", "MOVSD", "SCASB", "SCASW", "SCASD", "CMPSB", "CMPSW", "CMPSD", "INSB", "INSW", "INSD", "OUTSB", "OUTSW", "OUTSD" -- i.e., string instructions.)
