What type of output we will get in Field oriented control in motor control?
Normally square wave from MOSFET bridge (Using PWM control signal )
How to know the amplitude of our voltage waveform by inputs?
Using hall sensor BLDC controller will detect the presents of permanent magnet close to the armature coil and power up that armature, so armature coil and permanent magnet will repel each other, due to several poles the system will get a rotational field and the motor start runn
