I use a pic18f4550 and uses a 20mhz as it's clock source to run it at 48mhz.
Everything was fine until One day I couldn't enter debug mode.
I thought it was the oscialltor problem so I tried my code using internal osciallator and I could get in debug mode.
I didn't drop the crystal, maybe it bumped against some other stuff.
The pins were a little bent due to my bad breadboard.
Just wondering is it likely for the crystal to be broken.
it is this crystal. Crystal 20MHz - SparkFun Electronics
the documentation is here.
I would rather buy another crystal but since I need to order online and I need it soon I'd like to make sure first.
hi,
1.you can check the crystal using a oscilloscope to see if it is working or not
2.while programming have you disabled external crystal??
3.check the capacitors which is usually connected between the crystal pins and ground
4.you can get the crystal from a local shop i guess
