I need to define a broadband feed transition in hfss. But I dont know how to do it and ı dnot know any informatins which are about it. So, can you give to me informations and how to define it in hfss.?
I drew a sinoziodal antenna. it works between 16 - 30 GHz. I excited my antenna with a waveport. But the simulation solution was not good. in high frequencies patterns situation went to wrong. one of men of this forum said that if your antenna was a broadband antenna, you had to excite it with a broad feed tansition in hfss. So I asked this question. Can I use a broadband feed transition instead of a wave port?
for a broadband antenna analysis u need to have a transition as it is a unbalanced structure..there are so many baluns literature available on edaboard u can search here and also IEEE and MOTl u will find plenty..just see acco to ur req.
