tonyctsiu
Member level 1
I am developing a wind mill powered bright LED.
The windmill generates power from 0-30vAC depending on windspeed.
The target operating input voltage of the AC-DC circuit is 2-40vAC.
The LED operates at 3V or 6VDC (1-2LEDs)
I have found the papers below which discuss how to convert AC to DC efficiently without using bridge rectifier.
Paper 1: https://www.ijser.in/archives/v2i1/SjIwMTM4MQ==.pdf
Paper 2: https://digitalcommons.calpoly.edu/cgi/viewcontent.cgi?article=1219&context=eeng_fac
My question is, which circuit will yield more brightness from the LED under the same windspeed?
Are there still any AC-DC works better then those ones?
Thank you and best regards.
Tony Chun Tung Siu
Tony Chun Tung Siu
