In FDTD, the fields are known only at discrete points. Maxwell's equations are approximated using finite-differences which generates one equation for every field component at every point. These equations include field components at surrounding points. At the edge of your grid, you will be required to include a field component that is outside of your grid which really doesn't exist.
The manner in which you handle this is called a boundary condition. This is not to be confused with "boundary conditions" you learned in EM theory 101 where tangential fields are continuous, etc. At first, you might think you can handle this in some manner by simply storing one more layer of grid cells around your grid, but this leads to the same problem for the equations written for the fields in the new grid points you added.
The two most common boundary conditions are Dirichlet and Periodic Boundary conditions. To be clear, what you may read as the "Perfectly Matched Layer" is not really a boundary condition in the sense that it doesn't prescribe how to handle the problem you encounter implementing the finite-difference equations at the edge of your grid.
Dirichlet boundary conditions just assume fields outside the grid are all zero. This is "sort of" the boundary condition you would implement if didn't do anything. Forcing the fields to zero outside the grid makes the outside of the grid a "Perfect Electric Conductor" or a "Perfect Magnetic Conductor" depending on what field type you forced to be zero. Obviously, you would get reflections from a PEC or PMC so this is why you get reflections in FDTD if you do nothing about boundary conditions.
For periodic boundary conditions, you assume the fields outside the left side of your grid are the exact same as the fields at the far right side of your grid. Thus, you just use the fields at the right side of the grid in place of the fields outside the left side of the grid, and also the other way around.
The Perfectly Matched Layer is a way of "building in" loss into the outer 10 or so layers of your grid to absorb outgoing waves. This prevents their reflection, but doesn't tell you what to do at the very outside of your grid. Typically Dirichlet boundary conditions are used in conjunction with the PML.
Hope this helps!!
-Tip
