boundaries conditions microstrip-fed antenna
mitch81
Member level 1
hi,
I am working on a microstrip-fed antenna with CST software. I can not find the boundary conditions because the ground plane does not cover the entire substrate face! What are the settings I choose from the following figure?
for example if ground plane cover all underside of the substrate, i use Zmin (Et=0) and Zmax(open space). but in this case, what can i do?
please help me!
u should define the ground as infinite ground
your patch as perfect E
and a radiation box if this software is based on FEM,if it doesn't u don't need to determine a radiation box
hi there
you need to model the substrate ground plane. so you need to create a block for the ground plane and assign PEC or copper to this block
i hope this helps
regards
I am not sure, if I understand exactly. But you need chose Open (add space) everywhere and ground plane is thin PEC block (or copper).
I hope, that is answer to your question
hi
bondaries conditions for back groung of my antenna! just back ground condition!
mitch81 said:
hi
Open (add space) is correct
