Bound a register to specific type of flip-flop in Design Compiler
ebrahimi.khoy
Member level 3
Member level 3
I have two types of DFF in my library. How could I force design compiler to use a specific type of flip-flops for some registers?
For example for program counter, I intend to you type 1.
Thanks in advance for your help.
Either set_dont_use on type 2, but then it can be used at all.
Or, instantiate the flip flop with a size_only attribute, rather than infer it.
First synthesize the program counter keeping only type 1 cells in the target library. Then synthesize the entire design by adding type 2 cells also to the target library and placing a don't touch on program counter.
not sure - but i may be confused RC or DC have an attribute / command such as map_to_register and the required seq will be mapped to the specific reg libcell
DC have special commands for such kind of bound:
1. You create libcell subset (with your preffered DFFs) with define_libcell_subset
2. You bound your registers to this subset with set_libcell_subset
Example:
define_libcell_subset -family_name my_FFs -libcell_list {DFF1 DFF2}
set_libcell_subset -family_name my_FFs -object_list [get_cells {my_reg}]
