efiLabs
Newbie level 3
- Joined
- Aug 9, 2013
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 28
i'm currently working with a bosch cj125 and having problems with the Ri measurements.
i have seen a couple of posts related to oxygen sensors and was wondering if anyone has some experiences with it
the signal on pin UN appears to be distorted from the pump-current input at pin IA.
if there is anyone out there who worked with it it would be nice to share some thoughts.
i suspect that the chip is either internally damaged or the day code of the part i'm using has a problem.
also the bosch datasheet doesn't really explain which init1-reg bit to use for which phase of the sampling
i'm not asking for someone to do the design for me, just to share some common experiences
i would also be happy to post / share some embedded C++ code or other experiences with anyone who ever had their hands on a cj125 based project.
it's normally impossible to get any usable techie info from bosch unless you're mercedes, bmw or vw.
thanks and cheers, efiLabs
