* Project name:
Boot_Test (using mikroC Bootloader on PIC18's)
* Copyright:
(c) Mikroelektronika, 2008.
* Revision History:
20111017:
- initial release
* Description:
This is a serial port Bootloader implementation. All required bootloader
routines are placed in the boot18_32K file, the only thing that is
user-configurable is the baudrate of the UART communication, which is set
in the main() through appropriate call to Uart_Init(brg_reg).
Once started in PIC, the bootloader waits for a while (approx. 5 seconds)
to establish UART communication with the MikroBootloader application on the
PC. If it fails to do so, the bootloader starts the programme already
loaded in the MCU (initially it is just a NOP). If the communication is
established, the bootloader receives the hex file from the PC and places it
where requred (the MikroBootloader application reads out the hex file and
takes care of the location where hex is to be placed). When hex download
has finished, the user is notified by the MikroBootloader to reset the MCU,
and MCU enters the described bootload sequence again.
* Test configuration:
MCU: PIC18F45K22
http://ww1.microchip.com/downloads/en/DeviceDoc/41412D.pdf
Dev.Board: EasyPIC7
http://www.mikroe.com/easypic/
Oscillator: HS-PLL, 32.00000 MHz
Ext. Modules: None.
SW: mikroC PRO for PIC
http://www.mikroe.com/mikroc/pic/
* NOTES:
- It's recommended not to alter the start address of the main().
Otherwise, less space in ROM will be available for the application being bootloaded.
- RX and TX UART switches SW1.1, SW2.1 on EasyPIC7 should be turned On (board specific).
#pragma orgall 0x7CC0
#define BOOTLOADER_START_ADDR 0x7CC0
#define START_PROGRAM_ADDR 0x7FC0
static char block[64];
void Start_Program() org START_PROGRAM_ADDR{
unsigned short UART_Write_Loop(char send, char receive){
unsigned int rslt = 0;
while(1){
Delay_5ms();
UART1_Write(send);
Delay_5ms();
rslt++;
if (rslt == 0x0200)
return 0;
if (UART1_Read() == receive)
return 1;
void Write_Begin(){
FLASH_Erase_Write_64(START_PROGRAM_ADDR, block);
//--- goto main
block[0] = 0x60; //0xF03EEF60
block[1] = 0xEF;
block[2] = 0x3E;
block[3] = 0xF0;
void Start_Bootload(){
char i = 0, xx, yy;
long j = 0;
while (1) {
if (i == 64) {
//--- If 32 words (64 bytes) recieved then write to flash
if (!j)
Write_Begin();
if (j<BOOTLOADER_START_ADDR){
FLASH_Erase_Write_64(j, block);
i = 0;
j += 0x40;
//--- Ask for yy
UART1_Write('y');
while (!UART1_Data_Ready()) ;
//--- Read yy
yy = UART1_Read();
//--- Ask for xx
UART1_Write('x');
//--- Read xx
xx = UART1_Read();
//--- Save xxyy in block[i]
block[i++] = yy;
block[i++] = xx;
void main() org BOOTLOADER_START_ADDR{
ANSELC = 0; // Configure PORTC pins as digital
UART1_Init(115200); // Init USART at 115200
if (UART_Write_Loop('g','r')) { // Send 'g' for ~5 sec, if 'r'
Start_Bootload(); // received start bootload
else {
Start_Program(); // else start program
